Mifare RC522 RFID Kit
- Brands China Code: RFID-RC522
Note: The header pin is provided but it is NOT pre-soldered. Please be careful when doing the soldering work :)
NFC is a technology that uses Radio Frequency Identification (RFID) to transmit information wirelessly over short distances. It simplifies transactions, content sharing, and device pairing through a simple touch, making life more convenient for consumers worldwide. Additionally, NFC is compatible with millions of contactless cards and readers already deployed globally.
Both RC522 and PN532 are radio frequency chips from NXP company. RC522 supports ISO14443A protocol while PN532 supports the NFC function. Both chips have highly integrated modulation and demodulation circuits and can connect the output driver stage to the antenna with a small number of external devices. They also support ISO/IEC 14443 TypeA and MIFARE® communication protocols. Although the RC522 is a well-known RFID module for Arduino, the PN532 NFC RFID reader offers several advantages, especially in terms of communication options.
The communication distance with ISO 14443A/MIFARE® in reader mode is up to 50mm for both chips, depending on the length and tuning of the antenna. The PN532 chip has a unique “transmitter power down” feature that can turn off the internal antenna driver (turn off the RF field). It also has a built-in temperature sensor that automatically stops RF transmission when the chip temperature is too high. Not only that, you can also choose various types of communication with PN532 by changing between SPI, HSU (High-Speed UART), and I2C communication using the onboard mini switch.
How do I choose between these two modules?
It depends on your specific needs and requirements. If you only need to support the ISO14443A protocol, then RC522 is a very cost-effective option. However, if you want better performance and to support more protocols such as NFC, then you should choose the PN532 solution. Plus, you can go for PN532 if you decide to use HSU and I2C communication. It’s important to consider what protocols and features you need for your project before making a decision.
RC522
PN532
Mifare Card
PN532 NFC RFID Module Kit
RC522 RFID Module Kit
Mifare Card
