NodeMCU Kit using Telegram : Smoke and Flame Alert System
Project 5 : Smoke and Flame Alert System
  • Get an alert when theres is gas leakage or flame with IoT project using Telegram Bot
  • Required Components : ESP8266, Breadboard, MQ2 Sensor, Flame Sensor, two LEDs, two resistor (optional), nine Male-to-Female, two Female-to-Female jumper
Step 1 : Connect the jumper as the shown picture
Download the code here !
Output :
Related Posts
Create a Weather Monitoring System using Telegram Bot wit IoT technologies !..
