Wireless & IoT
Create a Weather Monitoring System using Telegram Bot wit IoT technologies !..
Cytron NodeMCU Starter Kit (Blynk)
Cytron NodeMCU Starter Kit is a complete kit with a guidebook that includes 6 example IoT projects to help beginners get started...
Set up a NAS with Raspberry Pi 5
Setup Network Attached Storage (NAS) using Raspberry Pi 5..
A fatal esptool.py error occurred: Cannot configure port!
This tutorial is short summarizes on common issues with ESP8266 or ESP32 Arduino base boards. It usually happens while tinkering with Arduino IDE and ESP chips...
Mobile Robot using TinyUSB
Wireless control of the mobile robot is made possible through the use of a wireless joystick via TinyUSB. In essence, this marks an improvement to the device information project by integrating the re..
Getting Started Guide with Robo Pico using CircuitPython
Robo Pico that is powered by Raspberry Pi Pico / Pico W and this getting started and projects guide will help you to kick start your Robo Pico projects w..
Maker Feather AIOT S3 Data Logging To Firebase
In this tutorial we shall see how we can data logging to firebase using Maker Feather AIOT S3..
How to Build a Real-Time Visitor Counter - IoT Project Tutorial
Do you run a store and want to keep track of the number of visitors? Or do you need to limit the number of people in your store at any given time?..
Getting Started with ESP32-CAM
Are you new to the ESP32-CAM development board? No problem! In this tutorial, we'll show you how to set up your board and get started with your first project...
Smart Farming: Using IoT to Monitor Your Agriculture
Are you looking for a way to remotely monitor the conditions of your agriculture farm? This IoT project can help. With the ability to collect and track data on soil moisture, precipitation trends, tem..
Sending Blynk Messages to An LCD with micro:bit
In this tutorial, we'll show you how to set up your micro:bit and Blynk app to communicate with each other, allowing you to send messages from the app to the micro:bit, which will then display them on..
Popular Industrial use cases for Raspberry Pi Computers
We will take a closer look at some of the most popular industrial use cases for Raspberry Pi computers and explore why they are becoming such a popular choice for industrial applications...
IoT Based Home Security Security System
Home is a place where we will feel safest the most. But with the crimes that might occur, there is always risk anywhere. How to build a good home security system?..
How To Control LED with Blynk Using Maker Feather AIOT S3
In this simple it is demonstrated how to get started with Blynk 2.0 and Maker Feather AIOT S3...
Displaying Real-Time Info on an LCD with micro:bit
In this tutorial, we're going to learn how to display real-time information such as date, time, and temperature on an LCD screen using micro:bit...
