I2C LCD Using micro:bit
- 23 May 2019
- 852
If you feel LED matrix on micro:bit is small enough to display any status, you can consider to use I2C LCD.
This video will show you how to display text on I2C LCD using micro:bit.
HARDWARE PREPARATION
- micro:bit Board
- Edge Breakout for micro:bit, I/O Expansion
- USB Micro B Cable
- BX-4112 Round Hole Bread Board
- I2C 1602 Serial LCD for Arduino & RPI
- BreadBoard Power Stick 5V 3V3
- Adapter 12V 1A (UK Plug)
- Male to Female Jumper Wire
- Female to Female Jumper Wire
This is the sample code used in the video. Please install LiquidCrystal I2C library from Frank de Brabander.
