![Getting Started With Favoriot IoT Platform Using Raspberry Pi Getting Started With Favoriot IoT Platform Using Raspberry Pi](https://static.cytron.io/image/tutorial/getting-started-favoriot-iot-platform-using-raspberry-pi/Pi-Favoriot.jpg)
- 20 Mar 2019
- 551
FAVORIOT offers an IOT platform specifically designed for any Internet of Things (IoT) projects. The platform is developed to support the integration of data from sensors and actuators on the internet. Collecting and storing data from IOT devices become much easier.
This tutorial will show you how to get start with Favoriot using Raspberry Pi. Before that, you might need to read following tutorial first:
This video will show you how to get started with Favoriot IoT platform using Raspberry Pi.
Untuk versi bahasa Melayu, sila rujuk link dibawah.
HARDWARE PREPARATION
Below is the list item used in the video.
- 16GB Micro SD Card
- Maker pHAT
- DHT22 Sensor Module Breakout
Wiring connection table
Raspberry Pi | DHT22 Sensor |
5V | VCC |
GND | GND |
18 | DAT |
![](https://static.cytron.io/image/tutorial/getting-started-favoriot-iot-platform-using-raspberry-pi/Pi-Favoriot-Connection.jpg)
This is sample code used in the video. Please replace "YOUR FAVORIOT APIKEY" and "Your Device Developer ID" with yours.
- Getting Started With Maker pHAT
- Displaying Sensor's Data On Blynk App Using Raspberry Pi
- Raspberry Pi Lesson: Send Data Favoriot
DHT22 Temperature and Humidity Sensor Module Br...
S$5.54 S$5.54
S$15.57 S$15.57
