Raspberry Pi
Control keyboard with gesture (APDS9960) using EDU PICO
This tutorial will guide you through the process of controlling your laptop keyboard effortlessly through gestures..
Creating Animation on OLED Display with EDU PICO
Creating Animation for OLED Display using GIF and Python using EDU PICO..
DIY Music Player with Gestures using EDU PICO
Learn how to craft your own MP3 player with gesture control capabilities using EDU PICO...
Setup 3.5-Inch TFT on Raspberry Pi 5
A guide on the setup and installation for 3.5-Inch 480x320 TFT 50FPS display on Raspberry Pi 5...
Setup 5 inch TFT Screen for Raspberry Pi 4
A guide on how to properly setup 5inch TFT Screen onto Raspberry Pi 4B and 5..
Raspberry Pi Imager: Updating Bootloader On A Raspberry Pi
Keeping your Raspberry Pi's firmware up-to-date is crucial for accessing new features, improvements, and bug fixes...
Edge Impulse with Raspberry Pi Pico Application Using Ultrasonic Sensor
Edge Impulse now supports devices with the RP2040 chip. The project uses the Raspberry Pi Pico with the RP2040 chip to create an ultrasonic ranger for distance measurement...
Edge Impulse with Raspberry Pi Pico Application Using ADC Light Sensor
Edge Impulse has the ability to interface with the Raspberry Pi Pico device, equipped with the RP2040 chip. In this project, data is gathered using the light sensor to measure light intensity...
Object Classification with Edge Impulse Using Raspberry Pi 4 and Camera Module
Raspberry Pi 4 seamlessly integrates with Edge Impulse, a versatile Linux board supporting the easy addition of a microphone or camera for efficient object classification projects...
DIY Fire Detection and Suppression with Raspberry Pi Pico
Learn how to build a fire detection and suppression system using a Raspberry Pi Pico, a flame sensor, and a water pump in this quick and easy video tutorial..
X-ray of Raspberry Pi 5 - Look inside the 1st Raspberry Pi Silicon Project - RP1
Is there any easter egg on the latest Raspberry Pi 5? Let's check out the X-ray image that we managed to get...
Can 3A/3.5A PSU power Raspberry Pi 5?
In this article we shall discuss if we can use 3A/3.5A PSU to power up Raspberry Pi 5...
Can I use Raspberry Pi 4 Enclosure for Raspberry Pi 5?
In this article we talk discuss if the Raspberry Pi 4 enclosure can be used for Raspberry 5...
IRIV PiControl: The Key to Enhanced Industrial Efficiency
Efficiency translates to profitability, and one of the essential metrics used to gauge it is Overall Equipment Effectiveness (OEE)..
Raspberry Pi Success Stories Across Industries
In this article, we take you on a journey through the remarkable achievements made possible by the Raspberry Pi..
