![Displaying Text Message on Dot Matrix Using Blynk App and Raspberry Pi Displaying Text Message on Dot Matrix Using Blynk App and Raspberry Pi](https://static.cytron.io/image/tutorial/displaying-text-message-dot-matrix-using-blynk-app-raspberry-pi/RPi-Blynk-Dot-Matrix.jpg)
- 09 Jan 2019
- 556
We have share a tutorial on how to display Telegram text message on dot matrix before. Now, the objectives still same, but we will send the text to Raspberry Pi through Blynk app.
- Displaying on MAX7219 Dot Matrix Using Raspberry Pi
- Controlling LED on Maker pHAT Using Raspberry Pi and Blynk
This video shows how to display text message on dot matrix using Blynk App and Raspberry Pi
HARDWARE PREPARATION
- Maker pHAT
- 16GB Micro SD Card
- 4 In 1 MAX7219 Dot Matrix Display Module
This sample code will read the text sent from Blynk app and display to MAX7219 dot matrix.
References
- blynk-library-python from vshymanskyy
- Luma.LED_Matrix, credit to Richard Hull.
S$8.93 S$8.93
S$15.57 S$15.57
