Bidirectional Visitor Counter using CircuitPython on Maker Nano RP2040
- 12 Apr 2022
- 1092
In this video I would like to share about a bidirectional visitor counter project that is programmed using CircuitPython on Maker Nano RP2040.
- Maker Nano RP2040
- IO Expansion for Nano
- Adjustable Infrared Sensor Switch
- I2C 1602 Serial LCD
- 12mm Momentary Push Button
- USB Micro B Cable
- 3D printing products
3D Printed Parts
You can download the STL file for casing here:
- Thingiverse - https://www.thingiverse.com/thing:5350543
This is CircuitPython sample program. You need to include this library in your CIRCUITPY/lib folder. You can download it from CircuitPython Library Bundle.
- simpleio.py
For lcd.py and i2c_pcf8574_interface.py, please save it in your CIRCUITPY/lib/lcd folder. Yes, you need to create the lcd folder in the lib folder.
