![Selfie with Raspberry Pi Selfie with Raspberry Pi](https://static.cytron.io/image/tutorial/selfie-raspberry-pi/photo_2018-11-01_14-54-20.jpg)
In this lesson, we will learn on how to use a push button to take a selfie using a Pi Camera. It’s simple and easy project to do.
HARDWARE PREPARATION
This tutorial use :
![](https://static.cytron.io/image/tutorial/selfie-raspberry-pi/photo_2018-11-01_14-54-20.jpg)
Thank you
