Power Up the Robo Pico
- 06 Jul 2023
- 726
This guide will show you how to power up your Robo Pico by choosing one of the 3 methods available.
We have 3 ways to power up the Robo Pico.
- USB micro B cable (5V)
- Single Cell Li-Po/Li-Ion Battery (3.7V)
- Vin (3.6-6V)
Method #1 : USB micro B cable (5V)
1. Use a USB micro B cable to connect your Raspberry Pi Pico / Pi Pico W to the computer.
2. Turn on the power switch on Robo Pico.
Note: Always switch on the Robo Pico while flashing the code or running your uploaded code.
Method #2 : Single Cell Li-Po / Li-Ion Battery (3.7V)
1. Connect a single Cell Li-Po / Li-Ion battery to the Li-Po battery connector.
Note: Note: The Single Cell Li-Po / Li-Ion battery can be recharged by using USB micro B cable to connect the Raspberry Pi Pico / Pi Pico W to a power source.
Method #3 : Vin (3.6-6V)
1. Insert AA batteries into a battery holder with exposed end wires.
2. Insert and tigthen the exposed end into the Vin terminal block (light green).
3. Turn on the power switch on Robo Pico.
Robo Pico
S$21.29 S$21.29
