![Controlling Relay via Telegram using Maker Pi Pico and CircuitPython Controlling Relay via Telegram using Maker Pi Pico and CircuitPython](https://static.cytron.io/image/cache/tutorial/controlling-relay-via-telegram-using-maker-pi-pico-and-circuitpython/RPi-Pico-Telegram-Relay-800x320.jpg)
- 28 Dec 2021
- 1519
This is the last tutorial for 2021, and I want to share about how to control the relay via the Telegram app using Maker Pi Pico and CircuitPython.
- adafruit_espatcontrol
- adafruit_requests.mpy
- simpleio.mpy
- Telegram Bot API
- GitHub - CTBot by Stefano Ledda
ESP-01 WiFi Serial Transceiver Module (ESP8266)
S$2.82 S$2.82
Grove - Relay
Discontinued
Maker Pi Pico & Kits: Simplifying Raspberry...
S$12.86++ S$12.86
