Build Auto Barrier Gate with Microbit
- 17 Aug 2022
- 1950
Automatic barriers are a common sight at the entrance of car parks and restricted areas. They control the flow of traffic, keep track of vehicles entering a property, and prevent unwarranted access to private properties.
In this tutorial, we will learn how to build an auto barrier gate using microbit with REKA:BIT.
- Connect the servo motor to the first port
- Connect Ultrasonic sensor to the first grove port in REKA:BIT (P1 to Trig, P0 to Echo)
Connect your REKA:BIT to your computer and open MakeCode editor to start programming.
- Add (REKA:BIT), and (makerbit-ultrasonic) extensions and follow the code block in the picture above
Project Complete
Upon completing the project successfully, the barrier gate will open once the car passes near the ultrasonic sensor.
