Tetris Game Using Raspberry Pi Pico 2
Creating a Tetris game using an OLED display and three buttons is an exciting project! Below is a step-by-step guide that covers the necessary components, wiring, and code.
Components Needed:
  1. Microcontroller: Raspberry Pi Pico 2
  2. OLED Display: 128x64 I2C OLED display.
  3. Buttons: 3 push buttons.
  4. Resistors: 10k ohm resistors for pull-down/pull-up resistors. (optional)
  5. Breadboard and wires. (optional)
Step 1: Setup the Hardware
1.1. Wiring the OLED Display
  • VCC to 5V on the Raspberry Pi Pico 2.
  • GND to GND on the Raspberry Pi Pico 2.
  • SCL to GP5 (or SCL pin on your Raspberry Pi Pico 2).
  • SDA to GP4 (or SDA pin on your Raspberry Pi Pico 2).
1.2. Wiring the Buttons (optional if not using the extended board)
Each button will be connected to a digital pin on the Raspberry Pi Pico 2. For simplicity, we'll use pull-up resistors.
  • Button 1:
    • One leg to GND.
    • The other leg to GP20
  • Button 2:
    • One leg to GND.
    • The other leg to GP21
  • Button 3:
    • One leg to GND.
    • The other leg to GP22
Step 2: Install Required Libraries
Get the library here
Step 3: Writing the Code
Get the code here
Step 4: Connect the Raspberry Pi Pico 2 to computer
Step 4: Testing
  • Upload the code to your Raspberry Pi Pico 2.
  • Ensure the OLED displays the game board and that the buttons move the pieces as expected.
  • Debug any issues by checking connections or serial outputs.
Video Output
