![Step Counter with micro:bit Step Counter with micro:bit](https://static.cytron.io/image/tutorial/step-counter-with-microBit/Step_counter_display_pic.png)
- 04 Feb 2023
- 1694
Do you want to keep track of your steps and make sure you're staying active every day? Well, we have the perfect solution for you! in this video, we will show you how to make a step counter using micro:bit.
- Follow the code block in the picture above
Project Complete
Every time you take a step the counter will increase by 1
micro:bit Junior Kit (V2)
S$30.36 S$30.36
