Raspberry Pi with PIR Sensor
In this lesson, we will learn on how to use a PIR sensor module with Raspberry Pi. It’s simple and easy project to detect a motion.
HARDWARE PREPARATION
This tutorial use :
- Raspberry Pi
- Maker Hat
- USB Micro B Cable
- Low Cost PIR Sensor Module
Thank you
