Measuring Distance Using Ultrasonic Sensor
In this project I’m using an ultrasonic sensor that can precisely measure the distance to show how a beep sound come out when a car is reversed. You will noticed that when the car is too near to the barrier behind the car, it will give a continuous beep sound. Let’s figure out how it works!
HARDWARE PREPARATION
This tutorial use :
CONNECTION | |
Ultrasonic Sensor : VCC | Maker UNO: 5V |
Ultrasonic Sensor : GND | Maker UNO: GND |
Ultrasonic Sensor : Trig | Maker UNO: pin 11 |
Ultrasonic Sensor : Echo | Maker UNO : pin 12 |
SAMPLE CODE
Reference
Thank you
