![Maker UNO DHT11 Alphanumeric Display Maker UNO DHT11 Alphanumeric Display](https://static.cytron.io/image/cache/tutorial/is-it-possible-to-program-maker-uno-with-python-3/2022-01-06_9-36-53-800x320.png)
- 08 Jan 2022
- 731
In this tutorial, it is demonstrated how to display the DHT11, temperature and humidity value on the alphanumeric display using Maker Uno.
Circuit
There is no additional circuit is required since we are using the grove sensor. The DHT11 is connected to port D2 and the alphanumeric display is connected to port i2C of the grove base V2.
#include
#include "grove_alphanumeric_display.h"
#include "DHT.h"
#define DHTPIN 2 // what digital pin we're connected to
#define DHTTYPE DHT11 // DHT 11
Seeed_Digital_Tube tube;
DHT dht(DHTPIN, DHTTYPE);
void setup() {
Wire.begin();
dht.begin();
tube.setTubeType(TYPE_2,TYPE_2_DEFAULT_I2C_ADDR);
tube.setBrightness(10);
tube.setBlinkRate(BLINK_OFF);
void loop() {
welcome();
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
tube.displayString("Humidity: ",100);
tube.displayNum(h,100);
delay(500);
tube.displayString("Temperature: ", 100);
tube.displayNum(t,100);
delay(500);
tube.displayString("°C ", 100);
delay(500);
void welcome()
tube.displayString("MAKER UNO + DHT11 + ALPHA DISPLAY", 100);
delay(500);
