![Interfacing Maker Nano RP2040 With DHT22 And Sparkfun SERLCD Interfacing Maker Nano RP2040 With DHT22 And Sparkfun SERLCD](https://static.cytron.io/image/tutorial/interfacing-makernanorp2040-with-dht22-and-sparkfun-serlcd/2-2.jpg)
- 24 May 2022
- 1225
In this tutorial today, we shall see how to interface Maker Nano RP2040 With DHT22 and Sparkfun serlcd. The Sparkfun serlcd is a RGB on black display, which gives a interesting view.
For this tutorial we will need the following components
![3 1](https://static.cytron.io/image/tutorial/interfacing-makernanorp2040-with-dht22-and-sparkfun-serlcd/3-1-1024x576.jpg)
Building The Circuit
Building the circuit is pretty straightforward since we will be using the grove connector and also the maker port connection.
Once the connection are made, we can now start to code.
Below is the complete code that we have used in this tutorial
#include
#include "DHT.h"
#include
#define DHTPIN 2
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
SerLCD lcd;
void setup() {
Wire.begin();
lcd.begin(Wire);
Wire.setClock(400000);
dht.begin();
lcd.clear();
lcd.setBacklight(255, 0, 0); //bright red
lcd.setCursor(0, 0);
lcd.print("MakerNano RP2040");
lcd.setCursor(1, 1);
lcd.print("DHT22 + SERLCD");
delay(2000);
void loop() {
delay(2000);
lcd.noBlink();
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
// Read temperature as Fahrenheit (isFahrenheit = true)
float f = dht.readTemperature(true);
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) || isnan(f)) {
Serial.println(F("Failed to read from DHT sensor!"));
return;
// Compute heat index in Fahrenheit (the default)
float hif = dht.computeHeatIndex(f, h);
// Compute heat index in Celsius (isFahreheit = false)
float hic = dht.computeHeatIndex(t, h, false);
Serial.print(F("Humidity: "));
Serial.print(h);
Serial.print(F("% Temperature: "));
Serial.print(t);
Serial.print(F("°C "));
Serial.print(f);
Serial.print(F("°F Heat index: "));
Serial.print(hic);
Serial.print(hif);
Serial.println(F("°F"));
lcd.setBacklight(0, 255, 0);
lcd.clear();
lcd.print("Temp: ");
lcd.print(t);
//lcd.print((char)223);
lcd.print("C");
lcd.setCursor(0, 1);
lcd.print("Humidity: ");
lcd.print(h);
//delay(2000);
Outcome
The lcd shows the value of the DHT22.
![1 2](https://static.cytron.io/image/tutorial/interfacing-makernanorp2040-with-dht22-and-sparkfun-serlcd/1-2-1024x576.jpg)
