![Interfacing Maker Nano RP2040 with Grove LED Bar and Grove Slide Potentiometer Interfacing Maker Nano RP2040 with Grove LED Bar and Grove Slide Potentiometer](https://static.cytron.io/image/tutorial/interfacing-maker-nano-rp2040-with-grove-led-bar-and-grove-slide-potentiometer/5.jpg)
- 25 Apr 2022
- 1196
In this tutorial it is shown how to interface Maker Nano RP2040 with Grove LED Bar and Grove Slide Potentiometer. Basically the purpose of this tutorial is to demo how to interface the devices together and to illustrate how this can be implemented in other projects such as to show volume level, temperature level, pressure level and etc.
The hardware setup for this tutorial is as shown below
![1 1](https://static.cytron.io/image/tutorial/interfacing-maker-nano-rp2040-with-grove-led-bar-and-grove-slide-potentiometer/1-1-1024x576.jpg)
![2 1](https://static.cytron.io/image/tutorial/interfacing-maker-nano-rp2040-with-grove-led-bar-and-grove-slide-potentiometer/2-1-1024x576.jpg)
Building The Circuit
- Constructing the circuit is pretty much easy since we are using the grove connector. The connection between the devices are done as per the below figure.
![4](https://static.cytron.io/image/tutorial/interfacing-maker-nano-rp2040-with-grove-led-bar-and-grove-slide-potentiometer/4-1024x576.jpg)
For the code, first we try to get the serial monitor reading. Next is the complete code.
#include
Grove_LED_Bar bar(3, 2, 0); // Clock pin, Data pin, Orientation
int adcPin = A0; // select the input pin for the potentiometer
int ledPin = A1; // select the pin for the LED
int adcIn = 0; // variable to store the value coming from the sensor
Serial.begin(9600); // init serial to 9600b/s
pinMode(ledPin, OUTPUT); // set ledPin to OUTPUT
Serial.println("Sliding Potentiometer Test Code!!");
// read the value from the sensor:
adcIn = analogRead(adcPin)/100;
if(adcIn >= 500) digitalWrite(ledPin,HIGH); // if adc in > 500, led light
else digitalWrite(ledPin, LOW);
Serial.println(adcIn);
bar.setLevel(adcIn);
delay(100);
#include
delay(100);
Outcome
This is the final output
![3 1](https://static.cytron.io/image/tutorial/interfacing-maker-nano-rp2040-with-grove-led-bar-and-grove-slide-potentiometer/3-1-1024x576.jpg)
