![Hungry Robot, powered by Maker Pi RP2040 and CircuitPython Hungry Robot, powered by Maker Pi RP2040 and CircuitPython](https://static.cytron.io/image/tutorial/hungry-robot-powered-by-maker-pi-rp2040-and-circuitpython/Hungry-Robot-Maker-Pi-RP2040.jpg)
- 22 Feb 2022
- 1204
Before this I have built a Hungry Robot using REKA:BIT. This time I want to try with Maker Pi RP2040 and program it using CircuitPython.
Download the STL files:
- REKA:BIT Hungry Robot - https://www.thingiverse.com/thing:5249030
- Maker Pi RP2040 to REKA:BIT Mounting Holes - https://www.thingiverse.com/thing:5257699
- adafruit_motor
- simpleio.mpy
Grove - Ultrasonic Ranger
S$8.18 S$8.18
Analog Micro Servo 9g (3V-6V)
S$4.29 S$4.29
Maker Pi RP2040 : Simplifying Robotics with Ras...
S$17.14 S$17.14
Artillery Hornet 3D Printer - Partially Assembled
Discontinued
Not Available
