Sending Blynk Messages to An LCD with micro:bit
- 10 Mar 2023
- 1865
In this tutorial, we'll show you how to set up your micro:bit and Blynk app to communicate with each other, allowing you to send messages from the app to the micro:bit, which will then display them on the connected LCD screen. But this project is not limited to just displaying messages. You can also use it to create reminders, make to-do lists, and more! The possibilities are endless, and we hope this tutorial will inspire you to explore different ways you can use this project to simplify your daily tasks.
- REKA:BIT with micro:bit
- Grove WiFi 8266 – IoT for micro:bit and beyond
- 3V3 I2C and SPI 1602 Serial Character LCD
- For the LCD, connect GND to VSS, 3V3 to VDD, SDA to SDA, SCL to SCK
Blynk Setup
- go to Blynk website, create a new account and log in
- create a new template
- from datastream add a virtual pin and change data type to (String)
- then add a new device
- now copy the token and paste it into the micro:bit code
- on your phone, open Blynk app and click on micro:bit device
- from the widget box, add a Terminal and select virtual pin 0
- Add “ESP8266 Cytron” extension
- Add "micro:bit + LCD" extension using this link: https://github.com/cytrontrainee/microbit-lcm1602-14-lcd-extension
- then follow the code block in the picture above
Project Complete
Type the message in Blynk terminal and it will be displayed on the LCD
