Measuring DC Motor RPM Through Built-in Hall Sensor Encoder
When we deal with controlling motor speed, normally we just provide PWM and the motor will rotate accordingly to the voltage reach at motor terminal. To have a better speed controlling, we can monitor RPM. Revolutions per minute (abbreviated rpm, RPM, rev/min, r/min) is the number of turns in one minute. It is a standard unit of rotational speed or the frequency of rotation around a fixed axis.
To monitor RPM, we need to have a feedback or sensor to sense shaft rotation. Luckily, nowadays, there have many DC motor in the market comes with built-in hall sensor encoder attach to the motor shaft. There have a few options offered by Cytron Technologies:
  1. SPG30 With Encoder (Spur Gear)
  2. IG32 With Encoder (Planetary Gear)
  3. IG42 With Encoder (Planetary Gear)
How it works? Please check on this video.
This tutorial uses:
  1. Maker UNO
  2. Cytron 10Amp DC Motor Driver
  3. DC Motor IG42E-24K
  4. Planetary Motor Bracket (IG42E/IG45)
  5. LiPo Rechargeable Battery 11.1V 2200mAH
  6. 2-3 Cell LIPO Balance Charger
You can make hardware connection based on the table below.
MD10C: +Battery +ve
MD30C: -Battery -ve
MD30C: AMotor red/black wire
MD30C: BMotor red/black wire
MD30C: GNDMaker UNO: GND
MD30C: PWMMaker UNO: pin 10
MD30C: DIRMaker UNO: pin 12
Motor brown wire (Hall sensor VCC)Maker UNO: 5V
Motor green wire (Hall sensor GND)Maker UNO: GND
Motor blue wire (Hall sensor A)Maker UNO: pin 3
Motor purple wire (Hall sensor B)Not connected
SAMPLE CODE
This is sample code used in the video. Enjoy it!
Thank you
