Measure The Ambient Temperature With Raspberry Pi Pico And Grove Temperature Sensor Using Arduino IDE
- 15 Jun 2022
- 2019
In this tutorial we shall see how to measure the ambient temperature with Raspberry Pi Pico and grove temperature sensor using Arduino IDE.
For this tutorial we will need the following components
Building The Circuit
The connection between the devices are as shown
Below is the complete code that we have used in this tutorial
#include
#include
#include
#include
#define SENSOR_PIN A0
#define REFERENCE_RESISTANCE 8000
#define NOMINAL_RESISTANCE 100000
#define NOMINAL_TEMPERATURE 25
#define B_VALUE 3950
// Define the connections pins
#define CLK 2
#define DIO 3
How many readings are taken to determine a mean temperature.
The more values, the longer a calibration is performed,
but the readings will be more accurate.
#define READINGS_NUMBER 10
Delay time between a temperature readings
from the temperature sensor (ms).
#define DELAY_TIME 10
// Create °C symbol
const uint8_t celsius1[] = {
SEG_A | SEG_B | SEG_F | SEG_G, // Circle
SEG_A | SEG_D | SEG_E | SEG_F // C
const uint8_t SEG_pico[] = {
SEG_A | SEG_B | SEG_E | SEG_F | SEG_G, // P
SEG_B | SEG_C, // i
SEG_A | SEG_D | SEG_E | SEG_F, // c
SEG_A | SEG_B | SEG_C | SEG_D | SEG_E | SEG_F // o
// Create display object of type TM1637Display
TM1637Display display = TM1637Display(CLK, DIO);
Thermistor* thermistor = NULL;
// the setup function runs once when you press reset or power the board
void setup() {
// Set the display brightness (0-7)
display.setBrightness(5);
// Clear the display
display.clear();
Thermistor* originThermistor = new NTC_Thermistor(
SENSOR_PIN,
REFERENCE_RESISTANCE,
NOMINAL_RESISTANCE,
NOMINAL_TEMPERATURE,
B_VALUE
thermistor = new AverageThermistor(
originThermistor,
READINGS_NUMBER,
DELAY_TIME
/* OR
new NTC_Thermistor(
SENSOR_PIN,
NOMINAL_RESISTANCE,
B_VALUE
READINGS_NUMBER,
DELAY_TIME
// the loop function runs over and over again forever
void loop() {
// Reads temperature
const double celsius = thermistor->readCelsius();
const double kelvin = thermistor->readKelvin();
const double fahrenheit = thermistor->readFahrenheit();
// Output of information
Serial.print("Temperature: ");
Serial.print(celsius);
Serial.print(" C, ");
Serial.print(kelvin);
Serial.print(" K, ");
Serial.print(fahrenheit);
Serial.println(" F");
display.setSegments(SEG_pico);
delay(1000);
display.showNumberDec(celsius, false, 2, 0);
display.setSegments(celsius1, 2, 2);
delay(100); // optionally, only to delay the output of information in the example.
