Maker Uno Portable GPS With DHT 11
In this tutorial, we shall see how we can build a Maker Uno portable GPS with DHT 11 using the Arduino Uno form shields and other electronic devices.
Building The Circuit
  1. Building the circuit for this tutorial is pretty straight forward since we have used the shield type board. Hence all the boards are stacked on top of another as shown in the video. The DHT 11 is connected to port D2 on the grove base shield and the lcd is connected to port I2C of the grove base shield as well.
maker uno gps with temperature logging time 0 01 0611
For the code, initially i have use a code to check if the GPS is giving the correct coordinate. Once we confirmed that the code is working fine and we are receiving the serial output, we use this data to feed to the u-center software.
  Demo code for GPS Shield
  It records the GPS information onto the TF card,
  and display on serial monitor as well.
  http://makerstudio.cc
#include
#include
#include
const int chipSelect = 10;
SoftwareSerial mySerial(6,7);//(RX,TX), (6->GPS_TX,7->GPS_RX)
  mySerial.begin(9600);
  pinMode(10, OUTPUT);
  if (!SD.begin(chipSelect)) {
    return;
  // make a string for assembling the data to log:
  char index = 0;
  char temp = 0;
  String dataString = "";
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  File dataFile = SD.open("datalog.txt", FILE_WRITE);
  if(dataFile)
  while(mySerial.available())
    temp = mySerial.read();
    Serial.print(temp);
    dataString += String(temp);
    index++;
    if(index>200)
      break;
  dataFile.print(dataString);
  dataFile.close();
  }else
  Serial.println("Open file failed");
Below is the output from the u-center software
1
2
3
Once we have confirmed the GPS data, now we can upload the final program and check the result.
#include
#include "DHT.h"
#include
#include
#include "rgb_lcd.h"
rgb_lcd lcd;
#define DHTPIN 2
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
// The TinyGPSPlus object
TinyGPSPlus gps;
void setup() {
  lcd.begin(16, 2);
  Serial.begin(115200);
  dht.begin();
void loop() {
  //put your main code here, to run repeatedly:
  while (mySerial .available() > 0)
  gps.encode(mySerial.read());
  double h = dht.readHumidity();
  double t = dht.readTemperature();
  Serial.print("Humidity: ");
  Serial.println(h);
  Serial.print("Temperature: ");
  Serial.println(t);
  lcd.setCursor(0, 0);
  lcd.print(gps.location.lat(), 5);
  lcd.setCursor(9, 0);
  lcd.print(gps.location.lng(), 5);
  lcd.setCursor(0, 1);
  lcd.print("T:");
  lcd.setCursor(2, 1);
  lcd.print(t);
  lcd.setCursor(9, 1);
  lcd.print("H:");
  lcd.setCursor(11, 1);
  lcd.print(h);
  displayInfo();
void displayInfo()
  Serial.print(F("Location: "));
  if (gps.location.isValid())
    Serial.print(gps.location.lat(), 6);
    Serial.print(F(","));
    Serial.print(gps.location.lng(), 6);
  else
    Serial.print(F("INVALID"));
  Serial.print(F("  Date/Time: "));
  if (gps.date.isValid())
    Serial.print(gps.date.month());
    Serial.print(F("/"));
    Serial.print(gps.date.day());
    Serial.print(gps.date.year());
  else
  Serial.print(F(" "));
  if (gps.time.isValid())
    if (gps.time.hour() < 10) Serial.print(F("0"));
    Serial.print(gps.time.hour());
    Serial.print(F(":"));
    if (gps.time.minute() < 10) Serial.print(F("0"));
    Serial.print(gps.time.minute());
    if (gps.time.second() < 10) Serial.print(F("0"));
    Serial.print(gps.time.second());
    Serial.print(F("."));
    if (gps.time.centisecond() < 10) Serial.print(F("0"));
    Serial.print(gps.time.centisecond());
  else
  Serial.println();
Outcome
output
