Monitor Soil Moisture With Maker Nano RP2040 And Maker Soil Moisture Sensor
- 29 Mar 2022
- 1624
Together with this, i have integrated the Grove DHT11, Grove 1602 LCD and 24 ring NeoPixel. All this devices are interfaced together using the Grove Shield for Arduino Nano.
This are the list of items used in this tutorial.
Building The Circuit
- Constructing the circuit is pretty much easy since we are using the grove connector. The connection between the devices are done as per the below figure.
For the code, since we have used different type of devices, please ensure that all the library has been downloaded prior to running this code.
#include "DHT.h"
#include
#include "rgb_lcd.h"
#include
#define DHTPIN 2 // what digital pin we're connected to
#define DHTTYPE DHT11 // DHT 11
#define LED_COUNT 24
#define LED_PIN 5
DHT dht(DHTPIN, DHTTYPE);
WS2812FX ws2812fx = WS2812FX(LED_COUNT, LED_PIN, NEO_RGB + NEO_KHZ800);
const int analogInPin = A0;
int sensorValue = 0;
rgb_lcd lcd;
void setup() {
dht.begin();
lcd.begin(16, 2);
ws2812fx.init();
ws2812fx.setBrightness(90);
ws2812fx.setSegment(0, 0, LED_COUNT-1, FX_MODE_FADE, WHITE, 2000, false);
ws2812fx.start();
void loop() {
delay(1000);
sensorValue = analogRead(analogInPin);
float h = dht.readHumidity();
float t = dht.readTemperature();
lcd.setCursor(0, 0);
lcd.print("Soil Sensor:");
lcd.setCursor(12, 0);
lcd.print(sensorValue);
lcd.setCursor(0, 1);
lcd.print("T:");
lcd.print(t);
lcd.setCursor(9, 1);
lcd.print("H:");
lcd.print(h);
ws2812fx.service();
if(sensorValue > 650){
ws2812fx.setSegment(0, 0, LED_COUNT-1, FX_MODE_FADE, GREEN, 100, false);
if(sensorValue <650 && sensorValue >554){
ws2812fx.setSegment(0, 0, LED_COUNT-1, FX_MODE_FADE, RED, 100, false);
if(sensorValue <554){
ws2812fx.setSegment(0, 0, LED_COUNT-1, FX_MODE_FADE, BLUE, 100, false);
Outcome
