Maker Nano RP2040 Interfacing With Maker Drive Using Arduino IDE
- 06 Apr 2022
- 1930
In this tutorial we shall see how to interface Maker Nano RP2040 with Maker Drive to control dc micro metal gear motor. The ultimate goal is to build a line following robot. And this is the first part of it, whereby we try to control the DC motor using the Maker Nano RP2040 and Maker Drive.
This are the list of items used in this tutorial.
Building The Circuit
- Constructing the circuit is pretty much easy since we are using the grove connector. The connection between the devices are done as per the below figure.
For the code, since we have used different type of devices, please ensure that all the library has been downloaded prior to running this code.
* THIS SOFTWARE IS PROVIDED IN AN "AS IS" CONDITION. NO WARRANTY AND SUPPORT
* IS APPLICABLE TO THIS SOFTWARE IN ANY FORM. CYTRON TECHNOLOGIES SHALL NOT,
* IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR CONSEQUENTIAL
* DAMAGES, FOR ANY REASON WHATSOEVER.
* DESCRIPTION:
* This example shows how to drive 2 motors using the PWM and DIR pins with
* 2-channel motor driver.
* CONNECTIONS:
* Arduino D3 - Motor Driver PWM 1 Input
* Arduino D4 - Motor Driver DIR 1 Input
* Arduino D9 - Motor Driver PWM 2 Input
* Arduino D17 - Motor Driver DIR 2 Input
* Arduino GND - Motor Driver GND
* AUTHOR : Kong Wai Weng
* COMPANY : Cytron Technologies Sdn Bhd
* WEBSITE : www.cytron.io
* EMAIL : support@cytron.io
#include "CytronMotorDriver.h"
// Configure the motor driver.
CytronMD motor1(PWM_DIR, 3, 4); // PWM 1 = Pin 3, DIR 1 = Pin 4.
CytronMD motor2(PWM_DIR, 9, 17); // PWM 2 = Pin 9, DIR 2 = Pin 17.
// The setup routine runs once when you press reset.
void setup() {
// The loop routine runs over and over again forever.
void loop() {
motor1.setSpeed(128); // Motor 1 runs forward at 50% speed.
motor2.setSpeed(-128); // Motor 2 runs backward at 50% speed.
delay(1000);
motor1.setSpeed(255); // Motor 1 runs forward at full speed.
motor2.setSpeed(-255); // Motor 2 runs backward at full speed.
delay(1000);
motor1.setSpeed(0); // Motor 1 stops.
motor2.setSpeed(0); // Motor 2 stops.
delay(1000);
motor1.setSpeed(-128); // Motor 1 runs backward at 50% speed.
motor2.setSpeed(128); // Motor 2 runs forward at 50% speed.
delay(1000);
motor1.setSpeed(-255); // Motor 1 runs backward at full speed.
motor2.setSpeed(255); // Motor 2 runs forward at full speed.
delay(1000);
delay(1000);
Outcome
