IoT Based Home Security Security System
- 07 Mar 2023
- 834
Home is a place where we will feel safest the most. But with the crimes that might occur, there is always risk anywhere. How to build a good home security system?
When this project is turned on, the PIR motion sensor will detect if there is a motion at where the sensor is placed, or when someone triggers the button. The LED that is placed in the house will turn on and the house owner will be notified about the intruder via V-One Cloud.
- Maker Feather AIoT S3
- Breadboard
- PIR Motion Sensor
- LED
- Push Button
- Onboard Neopixel
- 220 Ohm Resistor
- Jumpers
- Qwiic Cable
Circuit Diagram
Workflow Code
For PIR Sensor:
For Push Button:
