Gesture Control With Maker Nano RP2040 And APDS9960
In this tutorial today, we shall see how to interface Maker Nano RP2040, APDS 9960 and servo motor to perform a gesture control
For this tutorial we will need the following components
Building The Circuit
To interface all the components together, i have decided to built a simple circuit on a donut board. The circuit is as shown below
untitled sketch schem
Please do note that the Arduino shown in the image above is the classic Arduino Nano. I have this, because there is no library for Maker Nano RP2040 yet inside the Fritzing.
Below is the complete code that we have used in this tutorial
#include "Adafruit_APDS9960.h"
#include
Adafruit_APDS9960 apds;
Servo myservo1,myservo2;
// the setup function runs once when you press reset or power the board
void setup() {
  Serial.begin(115200);
  myservo1.attach(2);
  myservo2.attach(3);
  if (!apds.begin()) {
    Serial.println("failed to initialize device! Please check your wiring.");
  else Serial.println("Device initialized!");
  //gesture mode will be entered once proximity mode senses something close
  apds.enableProximity(true);
  apds.enableGesture(true);
// the loop function runs over and over again forever
void loop() {
  //read a gesture from the device
  uint8_t gesture = apds.readGesture();
  if (gesture == APDS9960_DOWN)
    Serial.println("v");
    myservo2.write(0);
  if (gesture == APDS9960_UP)
  Serial.println("^");
  myservo2.write(180);
  if (gesture == APDS9960_LEFT)
  Serial.println("<");
  myservo1.write(180);
  if (gesture == APDS9960_RIGHT)
  {Serial.println(">");
  myservo1.write(0);
