DIY Radar Using Arduino and Processing
- 02 Oct 2018
- 1030
This tutorial will guide you how to develop simple DIY radar using Arduino and Processing. Actually, there have a lot of tutorial you can refer to, but most of them is using ultrasonic sensor. In this tutorial, I will using Analog Distance Sensor (10-80cm).
This video will show you how to develop simple DIY radar using Arduino (Maker UNO) and Processing IDE.
ITEM USED IN THE VIDEO
- Maker UNO
- Analog Distance Sensor (10-80cm)
- TowerPro MG946R Metal Gear Servo
- Breadboard 8.5x5.5cm (400 Holes)
SAMPLE CODE
This is the sample code for Processing and Arduino used in the video.
References
