DIY Automated Vacuum Cleaner Using REKA:BIT With Micro:bit
- 04 Sep 2021
- 1265
Here, you are about to make an automated vacuum cleaner, it is super cool and efficient. This project will inspire you to make so many cool projects with REKA:BIT
Step 1: Components and Tools
- 1x Ultrasonic Sensor
- 1x Shaft Motor
- 1x 2WD Smart Robot Car Chassis
- 1x Battery Holder
Tools Required:
- 4 Blades 56mm Motor Propeller
- Cardboard
- Hot Glue Gun
- Scissor
- Tape
All listed components can be found on our website Cytron Technologies
Step 2: Assembly Car Chassis
Insert the fastener into the chassis after tearing off the yellow protection wrap of the chassis, the fastener, and the code wheel | |
Fix the motor to the chassis, then insert and tighten the screws.(note: the copper sheet of the leading wire of the motor should face outward, the same side of the wheel) | |
Insert the spacer and tighten the 8 screws to fix the hammer caster | |
Hold tight and insert the motor (protection fastener) into the wheel
Installation completed |
Step 3: Use Cardboard to Make the Vacuum Body
- Cut the cardboard based on the following dimensions as shown in the figure below
- Glue the two sides on the base
- Glue the back and front part
- Attach the top part using tape, so we can open and close the vacuum easily
- Bring another piece of cardboard to make a dust container as shown in the figures
Step 4: Connection
- Ultrasonic sensor will be connected to the first grove port
- Both of DC motor wheels will be connected to motor terminals
- The fan motor will be connected to the servo port, the red wire should be connected to the negative pin, and the black wire will be connected to the postive pin (that way the fan will rotate counter-clockwise)
- Note: the servo port will provide 6v to fan motor, therefore the motor will rotate at maximum speed
Step 5: Code
Well done!
There you have it .. now turn on REKA:BIT and let the vacuum cleaner start the work!
