Data Logging Using Favoriot IoT Platform and ESP32
- 27 Mar 2019
- 832
Instead of using Favoriot IoT platform with Raspberry Pi, we also can do it with ESP32 board. Before that, please refer the following tutorial first.
This video will show you how to store data into Favoriot IoT platform using ESP32 board.
Untuk versi bahasa Melayu sila rujuk video dibawah.
HARDWARE PREPARATION
Below is the list of items used in the video.
- Node32 Lite Wifi & Bluetooth Development Kit
- DHT22 Sensor Module Breakout
- Breadboard 16.5x5.5cm (830 Holes)
- Male to Male Jumper Wire
Wiring connection table.
Node32 Lite | DHT22 |
3.3V | VCC |
GND | GND |
25 | DAT |
This is sample code used in the video. Please replace "Your Favoriot APIKEY" and "Your Device Developer ID" with yours. This code is using following library:
