Controlling LED on Arduino using IR Remote
Infrared receiver, or IR receiver, is a device that receives and decodes infrared signal. When an infrared remote control is used on the IR receiver, the device will translate the signal and then transmit the information to other devices.
This video will show you how to control LEDs using IR remote on Arduino.
References :
Thank you
